Introduction
This guide will walk you through the replacement of a damaged USB board on the right side of your HP Chromebook 14-ak041dx. If you are unable to insert a device into the USB ports on the right side of your computer, or the device you insert is not being recognized by the computer, your USB board may be internally damaged, and may need to be replaced.
You will need a pair of tweezers and a Phillips screwdriver.
Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
