HP Chromebook CB2L Motherboard Replacement
  1. HP Chromebook CB2L Motherboard Replacement, Battery: step 1, image 1 of 2 HP Chromebook CB2L Motherboard Replacement, Battery: step 1, image 2 of 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Motherboard Replacement: step 2, image 1 of 3 HP Chromebook CB2L Motherboard Replacement: step 2, image 2 of 3 HP Chromebook CB2L Motherboard Replacement: step 2, image 3 of 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Motherboard Replacement: step 3, image 1 of 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Motherboard Replacement: step 4, image 1 of 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Motherboard Replacement: step 5, image 1 of 1
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Motherboard Replacement, Speaker: step 6, image 1 of 1
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Motherboard Replacement: step 7, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Motherboard Replacement: step 8, image 1 of 3 HP Chromebook CB2L Motherboard Replacement: step 8, image 2 of 3 HP Chromebook CB2L Motherboard Replacement: step 8, image 3 of 3
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Motherboard Replacement: step 9, image 1 of 1
    • Use the plastic opening tool to remove the speaker from back panel.
  10. HP Chromebook CB2L Motherboard Replacement, Motherboard: step 10, image 1 of 3 HP Chromebook CB2L Motherboard Replacement, Motherboard: step 10, image 2 of 3 HP Chromebook CB2L Motherboard Replacement, Motherboard: step 10, image 3 of 3
    • Disconnect the black wire which connects the audio port to the motherboard.
    • Use the plastic opening tool to lift the white tab.
    • Use the plastic opening tool to disconnect the gold strip which connects the audio port to the motherboard.
  11. HP Chromebook CB2L Motherboard Replacement: step 11, image 1 of 2 HP Chromebook CB2L Motherboard Replacement: step 11, image 2 of 2
    • Lift the black tab using the plastic opening tool.
    • Remove the two white strips from the motherboard.
  12. HP Chromebook CB2L Motherboard Replacement: step 12, image 1 of 2 HP Chromebook CB2L Motherboard Replacement: step 12, image 2 of 2
    • Lift the black and silver connector using plastic opening tool as shown.
    • Remove the white and black wires by rotating them counterclockwise and gently lifting them.
  13. HP Chromebook CB2L Motherboard Replacement: step 13, image 1 of 3 HP Chromebook CB2L Motherboard Replacement: step 13, image 2 of 3 HP Chromebook CB2L Motherboard Replacement: step 13, image 3 of 3
    • Remove the three 1.2mm screws using the Phillips #1 screwdriver.
  14. HP Chromebook CB2L Motherboard Replacement: step 14, image 1 of 1
    • Using the plastic opening tool lift the motherboard out of the back panel.
Gregory Hinkson
352 Reputation
3 Guides authored
USF Tampa, Team S2-G6, Lacy Spring 2017 Member of USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 649
