HP Chromebook x360 14-da0011dx Lower Case Replacement
  1. HP Chromebook x360 14-da0011dx Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Lower Case Replacement: step 2, image 1 of 2 HP Chromebook x360 14-da0011dx Lower Case Replacement: step 2, image 2 of 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Lower Case Replacement: step 3, image 1 of 3 HP Chromebook x360 14-da0011dx Lower Case Replacement: step 3, image 2 of 3 HP Chromebook x360 14-da0011dx Lower Case Replacement: step 3, image 3 of 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
One Comment
Where to get replacement parts for this one?
Aguinaldo Motta - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 57
All Time: 428
