HP Chromebox J5N50UT Hard Drive Replacement
  1. HP Chromebox J5N50UT Hard Drive Replacement, Bottom Cover: step 1, image 1 of 1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT Hard Drive Replacement: step 2, image 1 of 1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT Hard Drive Replacement: step 3, image 1 of 1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT Hard Drive Replacement: step 4, image 1 of 1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
  5. HP Chromebox J5N50UT Hard Drive Replacement, Bottom Shield: step 5, image 1 of 1
    • Lift the two pieces of mylar tape from the bracket.
  6. HP Chromebox J5N50UT Hard Drive Replacement: step 6, image 1 of 1
    • Using your Phillips #1 screwdriver, remove the four Phillips M2.5×4.0 screws that hold the shield in place.
  7. HP Chromebox J5N50UT Hard Drive Replacement: step 7, image 1 of 1
    • Insert your spudger into the gap between the bottom shield and the ports and gently pry to lift and remove the shield.
  8. HP Chromebox J5N50UT Hard Drive Replacement, WLAN Module: step 8, image 1 of 2 HP Chromebox J5N50UT Hard Drive Replacement, WLAN Module: step 8, image 2 of 2
    • Disconnect the white and black antenna cables from the module.
  9. HP Chromebox J5N50UT Hard Drive Replacement: step 9, image 1 of 3 HP Chromebox J5N50UT Hard Drive Replacement: step 9, image 2 of 3 HP Chromebox J5N50UT Hard Drive Replacement: step 9, image 3 of 3
    • Using your Phillips #1 screwdriver, remove the M2.0×3.0 screw from the upper left corner of the module.
    • Once the screw has been removed, the module will tilt up.
  10. HP Chromebox J5N50UT Hard Drive Replacement: step 10, image 1 of 2 HP Chromebox J5N50UT Hard Drive Replacement: step 10, image 2 of 2
    • Remove the WLAN module by pulling it away from the slot at an angle.
  11. HP Chromebox J5N50UT Hard Drive Replacement, Hard Drive: step 11, image 1 of 2 HP Chromebox J5N50UT Hard Drive Replacement, Hard Drive: step 11, image 2 of 2
    • Remove the Phillips M2.0×3.0 screw.
    • The hard drive will tilt up once the screw has been removed.
  12. HP Chromebox J5N50UT Hard Drive Replacement: step 12, image 1 of 2 HP Chromebox J5N50UT Hard Drive Replacement: step 12, image 2 of 2
    • Pull the hard drive at an angle to remove it from its slot.
3 other people completed this guide.
Ashley Marvin
685 Reputation
5 Guides authored
Ohio State, Team S1-G3, Whitney Fall 2018 Member of Ohio State, Team S1-G3, Whitney Fall 2018
OSU-WHITNEY-F18S1G3
2 Members
5 Guides authored
2 Comments
Could you indicate the SSD brand/model/capacity/interface so we can order upgrades without having to open up and do the same twice.
When Ze - Reply
actually you can flip open metal bracket with just one mylar tape
and there is 5 screws, not 4. if you look, you will see triangle arrow stamped on bracket indicating which screws to remove.
you can swap the ssd without removing the wifi board
do this all the time, saves a lot of steps
mapatouli - Reply
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 31
All Time: 2,743
