HP Compaq 2510p Bluetooth Adapter Replacement
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: step 1, image 1 of 1
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: step 2, image 1 of 1
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: step 3, image 1 of 1
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: step 4, image 1 of 1
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: step 5, image 1 of 1
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: step 6, image 1 of 1
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
3 other people completed this guide.
Derek Kohansky
297 Reputation
2 Guides authored
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 416
