HP Compaq 2510p Power/audio bar Replacement
  1. HP Compaq 2510p Power/audio bar Replacement, Power/audio bar: step 1, image 1 of 1
    • Locate the 4 screws in the four corners of the laptop screen.
    • The screws may be hidden underneath a small rubber pad.
    • Be sure to ground yourself and tools before working near electronics.
  2. HP Compaq 2510p Power/audio bar Replacement: step 2, image 1 of 1
    • Use a Flathead screwdriver to remove the 4 rubber covers over the 4 screws referenced in step 1.
  3. HP Compaq 2510p Power/audio bar Replacement: step 3, image 1 of 1
    • Once the rubber has been removed a screw will be revealed. Remove each of the four screws with your Philips head screwdriver.
  4. HP Compaq 2510p Power/audio bar Replacement: step 4, image 1 of 1
    • Insert your spudger along the top of the screen, separating the plastic cover and the screen
  5. HP Compaq 2510p Power/audio bar Replacement: step 5, image 1 of 1
    • Continue running your Flathead along the top of the screen until the top is completely separated.
  6. HP Compaq 2510p Power/audio bar Replacement: step 6, image 1 of 2 HP Compaq 2510p Power/audio bar Replacement: step 6, image 2 of 2
    • Pull the plastic covering of the screen towards the keyboard, exposing the inner workings of the screen.
  7. HP Compaq 2510p Power/audio bar Replacement: step 7, image 1 of 1
    • Locate the hinges at the bottom left, and right of the screen
  8. HP Compaq 2510p Power/audio bar Replacement: step 8, image 1 of 2 HP Compaq 2510p Power/audio bar Replacement: step 8, image 2 of 2
    • Separate the Power/Audio bar from the hinge by gently pulling.
  9. HP Compaq 2510p Power/audio bar Replacement: step 9, image 1 of 1
    • Flip the Power/Audio bar over exposing the ribbon wire and its connection to the Power/Audio bar.
  10. HP Compaq 2510p Power/audio bar Replacement: step 10, image 1 of 1
    • Separate the ribbon wire by gently pulling the wire from its socket.
    • The wire will be separated and the bar is free.
    • Be gentle as you pull.
Derek Kohansky
297 Reputation
2 Guides authored
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 393
