HP Compaq 2510p RAM Replacement
  1. HP Compaq 2510p RAM Replacement, RAM: step 1, image 1 of 1
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: step 2, image 1 of 1
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: step 3, image 1 of 1
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: step 4, image 1 of 1
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: step 5, image 1 of 1
    • Remove the old RAM by lifting it upwards, then pulling.
3 other people completed this guide.
Nathan Pereira
81 Reputation
1 Guide authored
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,016
