HP Compaq 6710b Keyboard Replacement
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Compaq 6710b Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Compaq 6710b Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Keyboard Replacement: step 2, image 1 of 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Keyboard Replacement: step 3, image 1 of 2 HP Compaq 6710b Keyboard Replacement: step 3, image 2 of 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Keyboard Replacement: step 4, image 1 of 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
4 other people completed this guide.
Khulan Orgil
1,171 Reputation
6 Guides authored
Cal Poly, Team 4-2, Maness Spring 2015 Member of Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Members
6 Guides authored
2 Guide Comments
No parts required to *replace* the keyboard?
David - Reply
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 13
All Time: 5,336
