HP Compaq 6910p Hard Drive Replacement
  1. HP Compaq 6910p Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Compaq 6910p Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Loosen the two 1.5 cm Phillips #1 screws that attach the cover of the hard drive .
    • Lift up the cover.
  2. HP Compaq 6910p Hard Drive Replacement: step 2, image 1 of 3 HP Compaq 6910p Hard Drive Replacement: step 2, image 2 of 3 HP Compaq 6910p Hard Drive Replacement: step 2, image 3 of 3
    • Loosen the 1.5 cm Phillips #1 screw attaching the hard drive to the laptop.
    • Locate the tab on the hard drive.
    • Use this tab to pull the hard drive toward the right side of the case.
    • Do not pull up on the tab!
    • Remove the hard drive.
Tyler Fricks
531 Reputation
5 Guides authored
Montana Tech, Team 3-2, Shirk Fall 2015 Member of Montana Tech, Team 3-2, Shirk Fall 2015
MTUM-SHIRK-F15S3G2
5 Members
5 Guides authored
1 Guide Comment
Good info we are getting here. keep up!
Isaac Kamwathi - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 5,280
