HP Compaq 6910p Processor Replacement
  1. HP Compaq 6910p Processor Replacement, Processor: step 1, image 1 of 2 HP Compaq 6910p Processor Replacement, Processor: step 1, image 2 of 2
    • Turn the laptop upside down.
    • Remove the fourteen 1.5 cm Phillips's #1 screws.
    • Remove the battery.
    • Remove three 0.3 cm Phillips #1 screws in the battery compartment.
  2. HP Compaq 6910p Processor Replacement: step 2, image 1 of 3 HP Compaq 6910p Processor Replacement: step 2, image 2 of 3 HP Compaq 6910p Processor Replacement: step 2, image 3 of 3
    • Slide the tabs upward to release the keyboard
    • Lift up the keyboard
    • Disconnect the cables attaching the keyboard to the laptop by lifting up the release tabs.
    • Use a spudger if you're having trouble lifting up the tabs.
  3. HP Compaq 6910p Processor Replacement: step 3, image 1 of 1
    • Remove the upper frame of the laptop
    • This part is difficult, so use a spudger if you're having trouble removing the frame.
  4. HP Compaq 6910p Processor Replacement: step 4, image 1 of 3 HP Compaq 6910p Processor Replacement: step 4, image 2 of 3 HP Compaq 6910p Processor Replacement: step 4, image 3 of 3
    • Loosen the four 1.5 cm Phillips #1 screws indicated in red.
    • Remove the heat sink to reveal the processor.
  5. HP Compaq 6910p Processor Replacement: step 5, image 1 of 1
    • Lift up the processor carefully to remove
7 other people completed this guide.
Tyler Fricks
531 Reputation
5 Guides authored
Montana Tech, Team 3-2, Shirk Fall 2015 Member of Montana Tech, Team 3-2, Shirk Fall 2015
MTUM-SHIRK-F15S3G2
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 30
All Time: 4,964
