HP Compaq C700 Keyboard Replacement
  1. HP Compaq C700 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Keyboard Replacement: step 2, image 1 of 3 HP Compaq C700 Keyboard Replacement: step 2, image 2 of 3 HP Compaq C700 Keyboard Replacement: step 2, image 3 of 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Keyboard Replacement: step 3, image 1 of 1
    • Gently lift up and remove the keyboard.
Taylor Johansen
690 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Martin Fall 2016 Member of UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Members
6 Guides authored
2 Guide Comments
er zijn 3 schroeven aan het keyboard
marcel - Reply
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
azusa - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 934
