HP Compaq C700 RAM Replacement
  1. HP Compaq C700 RAM Replacement, RAM: step 1, image 1 of 1
    • It is recommended that the computer be powered off while working to avoid risk of electrocution.
    • Turn off the computer by pressing and hold the power button located above the keyboard.
  2. HP Compaq C700 RAM Replacement: step 2, image 1 of 1
    • Locate two phillips head 3 mm length screws on the hatch.
    • Using the PH0 screwdriver, remove the screws.
  3. HP Compaq C700 RAM Replacement: step 3, image 1 of 1
    • Lift up the hatch.
  4. HP Compaq C700 RAM Replacement: step 4, image 1 of 1
    • Using the plastic opening tool, open the locks by inserting the tool on the side of the beige locks to release the RAM.
  5. HP Compaq C700 RAM Replacement: step 5, image 1 of 1
    • Gently pull out the RAM.
4 other people completed this guide.
Khang Nguyen
173 Reputation
1 Guide authored
UMass Dartmouth, Team 5-6, Martin Fall 2016 Member of UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,097
