HP Compaq C700 Touchpad Replacement
  1. HP Compaq C700 Touchpad Replacement, Keyboard: step 1, image 1 of 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Touchpad Replacement: step 2, image 1 of 3 HP Compaq C700 Touchpad Replacement: step 2, image 2 of 3 HP Compaq C700 Touchpad Replacement: step 2, image 3 of 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Touchpad Replacement: step 3, image 1 of 1
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Touchpad Replacement, Touchpad: step 4, image 1 of 1
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  5. HP Compaq C700 Touchpad Replacement: step 5, image 1 of 1
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  6. HP Compaq C700 Touchpad Replacement: step 6, image 1 of 1
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  7. HP Compaq C700 Touchpad Replacement: step 7, image 1 of 1
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  8. HP Compaq C700 Touchpad Replacement: step 8, image 1 of 1
    • Gently lift and pull out the card.
  9. HP Compaq C700 Touchpad Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Locate the power button connector wire.
    • Using the tweezers, unhook the wire.
  10. HP Compaq C700 Touchpad Replacement: step 10, image 1 of 2 HP Compaq C700 Touchpad Replacement: step 10, image 2 of 2
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  11. HP Compaq C700 Touchpad Replacement: step 11, image 1 of 3 HP Compaq C700 Touchpad Replacement: step 11, image 2 of 3 HP Compaq C700 Touchpad Replacement: step 11, image 3 of 3
    • Unplug the remaining wires using the tweezers.
  12. HP Compaq C700 Touchpad Replacement: step 12, image 1 of 1
    • Gently pull out the three wires.
  13. HP Compaq C700 Touchpad Replacement: step 13, image 1 of 2 HP Compaq C700 Touchpad Replacement: step 13, image 2 of 2
    • Locate the four 3 mm Phillips head screws.
  14. HP Compaq C700 Touchpad Replacement: step 14, image 1 of 1
    • Unhook the display connector wire.
  15. HP Compaq C700 Touchpad Replacement: step 15, image 1 of 1
    • Gently disconnect the display by pulling it upwards.
  16. HP Compaq C700 Touchpad Replacement: step 16, image 1 of 1
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  17. HP Compaq C700 Touchpad Replacement: step 17, image 1 of 1
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  18. HP Compaq C700 Touchpad Replacement: step 18, image 1 of 1
    • Disconnect the touchpad connection using the tweezers.
  19. HP Compaq C700 Touchpad Replacement: step 19, image 1 of 1
    • Use the plastic opening tool to pry up all sides of the device cover.
  20. HP Compaq C700 Touchpad Replacement: step 20, image 1 of 1
    • Remove the cover by lifting it.
  21. HP Compaq C700 Touchpad Replacement: step 21, image 1 of 1
    • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
  22. HP Compaq C700 Touchpad Replacement: step 22, image 1 of 1
    • Use the tweezers to remove the touchpad wire connection.
  23. HP Compaq C700 Touchpad Replacement: step 23, image 1 of 2 HP Compaq C700 Touchpad Replacement: step 23, image 2 of 2
    • Use the plastic opening tool to pry up the touchpad cover.
    • Lift and remove the touchpad cover.
  24. HP Compaq C700 Touchpad Replacement: step 24, image 1 of 1
    • Use the blow dryer to melt the adhesive around the edge of the touchpad.
    • The touchpad is now free to be removed.
Taylor Johansen
690 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Martin Fall 2016 Member of UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Members
6 Guides authored
1 Guide Comment
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,538
