HP Compaq NC6120 Cooling Fan Replacement
  1. HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 1
    • Locate cooling fan directly to the left of copper heat sink.
  2. HP Compaq NC6120 Cooling Fan Replacement: step 2, image 1 of 2 HP Compaq NC6120 Cooling Fan Replacement: step 2, image 2 of 2
    • Locate the black/grey/brown colored cord and carefully disconnect it from the motherboard.
    • Place cord off to the side so that it is out of the way.
  3. HP Compaq NC6120 Cooling Fan Replacement: step 3, image 1 of 2 HP Compaq NC6120 Cooling Fan Replacement: step 3, image 2 of 2
    • Locate and remove the two 7.0mm Phillips #1 screws on the top left and top right corners of the cooling fan.
  4. HP Compaq NC6120 Cooling Fan Replacement: step 4, image 1 of 2 HP Compaq NC6120 Cooling Fan Replacement: step 4, image 2 of 2
    • Remove the fan from its spot.
Mateo Cuellar
601 Reputation
4 Guides authored
Cal Poly, Team 17-4, Forte Spring 2015 Member of Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 667
