HP Compaq NC6120 Mouse Pad Replacement
  1. HP Compaq NC6120 Mouse Pad Replacement, Disassembling HP Compaq NC6120 Laptop: step 1, image 1 of 3 HP Compaq NC6120 Mouse Pad Replacement, Disassembling HP Compaq NC6120 Laptop: step 1, image 2 of 3 HP Compaq NC6120 Mouse Pad Replacement, Disassembling HP Compaq NC6120 Laptop: step 1, image 3 of 3
    • Flip laptop so the backside is facing upwards.
    • Pull the two plastic switches at the top of the backside of the computer outwards, and remove the battery.
  2. HP Compaq NC6120 Mouse Pad Replacement: step 2, image 1 of 2 HP Compaq NC6120 Mouse Pad Replacement: step 2, image 2 of 2
    • Remove all 13 screws from the back panel of the computer (includes the two torx screws under the battery and the two under the ram memory panel).
    • Remove the four screws at the hinge of the computer (also attaching the back panel to the rest of the computer).
    • All screws are 9.8mm 3.0 flatheads except for the two under the battery which are T9 torx.
  3. HP Compaq NC6120 Mouse Pad Replacement: step 3, image 1 of 2 HP Compaq NC6120 Mouse Pad Replacement: step 3, image 2 of 2
    • Open up the laptop so that the screen is facing towards you. Push the monitor back until it is flat, parallel to the keyboard.
  4. HP Compaq NC6120 Mouse Pad Replacement: step 4, image 1 of 2 HP Compaq NC6120 Mouse Pad Replacement: step 4, image 2 of 2
    • Using the iFixit opening tool, remove the plastic panel located between the keyboard and monitor. It should pop off easily with the spudger and can then be pulled away.
  5. HP Compaq NC6120 Mouse Pad Replacement: step 5, image 1 of 2 HP Compaq NC6120 Mouse Pad Replacement: step 5, image 2 of 2
    • Remove the white cable attached to the just-removed plastic panel from the motherboard.
  6. HP Compaq NC6120 Mouse Pad Replacement: step 6, image 1 of 2 HP Compaq NC6120 Mouse Pad Replacement: step 6, image 2 of 2
    • Flip the keyboard away from the monitor, rotating it so that the keys are face down on the mousepad. Remove the black cord at the bottom of the keyboard that connects it to the motherboard. The keyboard is now free and can be removed.
  7. HP Compaq NC6120 Mouse Pad Replacement: step 7, image 1 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 7, image 2 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 7, image 3 of 3
    • Remove the two 9.8mm 3.0 flathead screws. There is one at each of the hinges.
  8. HP Compaq NC6120 Mouse Pad Replacement: step 8, image 1 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 8, image 2 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 8, image 3 of 3
    • Unplug the black cable with rectangular white plastic head from the motherboard. It is located at the top left of the motherboard, directly below the left hinge.
  9. HP Compaq NC6120 Mouse Pad Replacement: step 9, image 1 of 2 HP Compaq NC6120 Mouse Pad Replacement: step 9, image 2 of 2
    • Pull the monitor directly upwards from where it lay. The two metal hinges should easily slide out of their holes and the monitor will be disconnected from the motherboard.
  10. HP Compaq NC6120 Mouse Pad Replacement: step 10, image 1 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 10, image 2 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 10, image 3 of 3
    • Using the iFixit opening tool, pry the black plastic panel (with mousepad) off of the motherboard.
  11. HP Compaq NC6120 Mouse Pad Replacement: step 11, image 1 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 11, image 2 of 3 HP Compaq NC6120 Mouse Pad Replacement: step 11, image 3 of 3
    • Unplug the white cord connecting the mousepad to the motherboard from the motherboard, and pull off the entire plastic panel.
  12. HP Compaq NC6120 Mouse Pad Replacement, Mouse Pad: step 12, image 1 of 1
    • Refer to the laptop disassembly guide.
  13. HP Compaq NC6120 Mouse Pad Replacement: step 13, image 1 of 1
    • Find the green chip encased by an aluminum frame on the underside of the plastic panel that was removed last in the computer disassembly guide.
  14. HP Compaq NC6120 Mouse Pad Replacement: step 14, image 1 of 1
    • Remove the two 3.5mm Phillips #00 screws located at the bottom of the aluminum frame.
  15. HP Compaq NC6120 Mouse Pad Replacement: step 15, image 1 of 1
    • Slowly slide the frame in the direction of the keyboard hole on the plastic panel until the frame is released from the metal latches.
  16. HP Compaq NC6120 Mouse Pad Replacement: step 16, image 1 of 1
    • Slowly remove the frame without tearing the black fabric.
  17. HP Compaq NC6120 Mouse Pad Replacement: step 17, image 1 of 1
    • Carefully slide blue plastic connector on the mousepad towards the screw holes.
  18. HP Compaq NC6120 Mouse Pad Replacement: step 18, image 1 of 1
    • Remove the mousepad.
Mateo Cuellar
601 Reputation
4 Guides authored
Cal Poly, Team 17-4, Forte Spring 2015 Member of Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 529
