HP Compaq NC6120 RAM Replacement
  1. HP Compaq NC6120 RAM Replacement, RAM: step 1, image 1 of 1
    • Locate the plastic casing covering the RAM chip.
    • The plastic casing is found on the back side of the laptop, in the middle of the base panel.
  2. HP Compaq NC6120 RAM Replacement: step 2, image 1 of 2 HP Compaq NC6120 RAM Replacement: step 2, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the M2 screw securing the plastic casing covering the RAM chip.
    • Now remove the plastic casing and you should see the RAM chip.
  3. HP Compaq NC6120 RAM Replacement: step 3, image 1 of 3 HP Compaq NC6120 RAM Replacement: step 3, image 2 of 3 HP Compaq NC6120 RAM Replacement: step 3, image 3 of 3
    • Remove the RAM chip from underneath the casing.
    • It should easily pop out.
  4. HP Compaq NC6120 RAM Replacement: step 4, image 1 of 1
    • Replace the RAM chip with a new RAM chip.
3 other people completed this guide.
Keenan
494 Reputation
2 Guides authored
Cal Poly, Team 17-4, Forte Spring 2015 Member of Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,942
