HP Compaq Presario CQ56-110US RAM Replacement
Jorge Villarreal
Jorge Villarreal and 3 other contributors
Last updated on May 25, 2017
5 - 7 minutes
Easy
Introduction
Go to step 1
Use this guide to replace the RAM stick. If your computer freezes up momentarily while running several programs, this may be the guide for you.
Tools
  1. HP Compaq Presario CQ56-110US RAM Replacement, RAM: step 1, image 1 of 1
    • Ensure the laptop is unplugged and completely powered off. Loosen the three small screws using a #1 Phillips screwdriver.
    • The screws do not come free from the panel. They only need to be loosened enough so the panel can be lifted/pried.
  2. HP Compaq Presario CQ56-110US RAM Replacement: step 2, image 1 of 1
    • Carefully pry the panel up using a plastic opening tool.
    • Pull the panel away from the laptop and set it off to the side.
  3. HP Compaq Presario CQ56-110US RAM Replacement: step 3, image 1 of 2 HP Compaq Presario CQ56-110US RAM Replacement: step 3, image 2 of 2
    • Locate the latches on the RAM
    • Push the latches away from the RAM
  4. HP Compaq Presario CQ56-110US RAM Replacement: step 4, image 1 of 1
    • Carefully pry the RAM upwards
    • Remove the RAM
2 other people completed this guide.
Jorge Villarreal
150 Reputation
1 Guide authored
USF Tampa, Team 8-4, Eyestone Spring 2017 Member of USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 986
