HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement
  1. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 3 HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 2 of 3 HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 3 of 3
    • Use a Phillips screwdriver with a PH1 bit to loosen the three indicated screws.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: step 2, image 1 of 2 HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: step 2, image 2 of 2
    • Gently pull the black and white cables to disconnect them from the Wi-Fi card.
  3. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: step 3, image 1 of 1
    • Use the same screwdriver to remove the two 3 mm screws holding the card in place.
  4. HP Compaq Presario CQ56-110US Repair Wi-Fi Card Replacement: step 4, image 1 of 1
    • Lift the Wi-Fi card to remove it from the slot.
3 other people completed this guide.
Blanette Baltimore
255 Reputation
1 Guide authored
USF Tampa, Team 8-4, Eyestone Spring 2017 Member of USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 984
