HP Compaq Presario V3000 RAM Replacement
  1. HP Compaq Presario V3000 RAM Replacement, RAM: step 1, image 1 of 2 HP Compaq Presario V3000 RAM Replacement, RAM: step 1, image 2 of 2
    • Locate the two screws holding the RAM cover in place
    • Use Phillips #0 screwdriver to remove the two 4.5mm Philips head screws
    • Place screws on magnetic mat to help avoid losing the screws
    • Lift the RAM cover towards the battery eject latch
  2. HP Compaq Presario V3000 RAM Replacement: step 2, image 1 of 3 HP Compaq Presario V3000 RAM Replacement: step 2, image 2 of 3 HP Compaq Presario V3000 RAM Replacement: step 2, image 3 of 3
    • Lift foil covering RAM retention clips
    • Only pull the foil until the retention clips are visible. Do NOT continue pulling after.
    • Retention clips should be on the sides of the RAM chip
  3. HP Compaq Presario V3000 RAM Replacement: step 3, image 1 of 3 HP Compaq Presario V3000 RAM Replacement: step 3, image 2 of 3 HP Compaq Presario V3000 RAM Replacement: step 3, image 3 of 3
    • Push retention clip on each side of RAM OUTWARDS
    • RAM will pop up
  4. HP Compaq Presario V3000 RAM Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, carefully pull the RAM chip away from the RAM slot
  5. HP Compaq Presario V3000 RAM Replacement: step 5, image 1 of 3 HP Compaq Presario V3000 RAM Replacement: step 5, image 2 of 3 HP Compaq Presario V3000 RAM Replacement: step 5, image 3 of 3
    • Push retention clip on each side of the second RAM chip OUTWARDS
    • RAM chip will pop up
  6. HP Compaq Presario V3000 RAM Replacement: step 6, image 1 of 1
    • Repeat Step 5 and use tweezers to carefully pull RAM away from RAM slot
Bernard Lee
122 Reputation
1 Guide authored
IUPUI, Team S1-G1, Harley Spring 2017 Member of IUPUI, Team S1-G1, Harley Spring 2017
IUPUI-HARLEY-S17S1G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 3,393
