HP Compaq Presario V5303NR Cooling Fan Replacement
  1. HP Compaq Presario V5303NR Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 3 HP Compaq Presario V5303NR Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 3 HP Compaq Presario V5303NR Cooling Fan Replacement, Cooling Fan: step 1, image 3 of 3
    • Turn the laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Remove the battery from its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR Cooling Fan Replacement: step 2, image 1 of 2 HP Compaq Presario V5303NR Cooling Fan Replacement: step 2, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
    • Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
    • Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
    • Keep the different types of screws separate from one another. They will only fit into holes created for screws of their size, and thus cannot fit into other screw holes.
  3. HP Compaq Presario V5303NR Cooling Fan Replacement: step 3, image 1 of 2 HP Compaq Presario V5303NR Cooling Fan Replacement: step 3, image 2 of 2
    • Remove the laptops bottom panel.
  4. HP Compaq Presario V5303NR Cooling Fan Replacement: step 4, image 1 of 2 HP Compaq Presario V5303NR Cooling Fan Replacement: step 4, image 2 of 2
    • Use the metal spudger to pry open the two metal latches affixing the fan cover to the laptop.
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw affixing the fan cover to the laptop.
    • A plastic spudger has a decreased risk of damaging the computer and its components, so it would normally be preferred over the metal. However, due to the limited amount of space between the latch and the fan's casing, the plastic one may not fit, as was the case in the photo above.
  5. HP Compaq Presario V5303NR Cooling Fan Replacement: step 5, image 1 of 1
    • Remove the fan cover.
  6. HP Compaq Presario V5303NR Cooling Fan Replacement: step 6, image 1 of 3 HP Compaq Presario V5303NR Cooling Fan Replacement: step 6, image 2 of 3 HP Compaq Presario V5303NR Cooling Fan Replacement: step 6, image 3 of 3
    • Carefully unplug the plastic piece at the end of the wire from the motherboard at the highlighted point.
    • Carefully remove said plastic piece from the end of the wire bundle at the end of the wire.
    • Do not lose this plastic piece, as it plugs the fan into the fan's power supply.
    • Be very careful to avoid damaging any of the components listed above. If any of these parts are damaged, the fan, if not the computer as a whole, could be irreparably damaged.
  7. HP Compaq Presario V5303NR Cooling Fan Replacement: step 7, image 1 of 1
    • Use the Phillips #00 screwdriver on the three 4mm #00 screws affixing the fan to the laptop.
  8. HP Compaq Presario V5303NR Cooling Fan Replacement: step 8, image 1 of 2 HP Compaq Presario V5303NR Cooling Fan Replacement: step 8, image 2 of 2
    • Carefully unweave the fan's wire from the two highlighted overhangs holding it in place.
    • The first image shows the white plastic piece still attached to the wire. This was an oversight on the photographers. If you have followed the guide to this point, this piece should already have been removed.
    • Feed the wire and wire bundle through the hole in the fan case.
  9. HP Compaq Presario V5303NR Cooling Fan Replacement: step 9, image 1 of 1
    • Remove the cooling fan, alongside its wire, from the fan's casing.
Chris Obesky
617 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 458
