HP Compaq nc6400 Optical Drive Replacement
  1. HP Compaq nc6400 Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Optical Drive Replacement: step 2, image 1 of 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Optical Drive Replacement: step 3, image 1 of 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Optical Drive Replacement: step 4, image 1 of 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: step 5, image 1 of 2 HP Compaq nc6400 Optical Drive Replacement, Optical Drive: step 5, image 2 of 2
    • Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
  6. HP Compaq nc6400 Optical Drive Replacement: step 6, image 1 of 2 HP Compaq nc6400 Optical Drive Replacement: step 6, image 2 of 2
    • Press and release the eject icon to partially eject the optical drive.
    • Use of a spudger may be necessary to pry open the optical drive.
  7. HP Compaq nc6400 Optical Drive Replacement: step 7, image 1 of 1
    • Grasp the sides and pull the optical drive out.
2 other people completed this guide.
Chad Williams
252 Reputation
1 Guide authored
Cal Poly, Team 14-6, Forte Fall 2013 Member of Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 4,608
