HP Compaq nc6400 RAM Replacement
  1. HP Compaq nc6400 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 RAM Replacement: step 2, image 1 of 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 RAM Replacement: step 3, image 1 of 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 RAM Replacement: step 4, image 1 of 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 RAM Replacement, RAM: step 5, image 1 of 2 HP Compaq nc6400 RAM Replacement, RAM: step 5, image 2 of 2
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
  6. HP Compaq nc6400 RAM Replacement: step 6, image 1 of 1
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
  7. HP Compaq nc6400 RAM Replacement: step 7, image 1 of 2 HP Compaq nc6400 RAM Replacement: step 7, image 2 of 2
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
  8. HP Compaq nc6400 RAM Replacement: step 8, image 1 of 1
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
  9. HP Compaq nc6400 RAM Replacement: step 9, image 1 of 2 HP Compaq nc6400 RAM Replacement: step 9, image 2 of 2
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
5 other people completed this guide.
Luis Vazquez
401 Reputation
2 Guides authored
Cal Poly, Team 14-6, Forte Fall 2013 Member of Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 4,630
