HP Deskjet 1000 J110a Parts Replacement
  1. HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: step 1, image 1 of 3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: step 1, image 2 of 3 HP Deskjet 1000 J110a  Parts Replacement, Cover Removal: step 1, image 3 of 3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a  Parts Replacement: step 2, image 1 of 3 HP Deskjet 1000 J110a  Parts Replacement: step 2, image 2 of 3 HP Deskjet 1000 J110a  Parts Replacement: step 2, image 3 of 3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a  Parts Replacement: step 3, image 1 of 1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
2 other people completed this guide.
Colin Tourjee
632 Reputation
4 Guides authored
USF Tampa, Team S5-G3, Passmore Spring 2018 Member of USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
4 Members
12 Guides authored
2 Comments
Very intuitive, good instructions. Highly recommended.
Krzysztof Białkowski - Reply
Thank you very much for the instructions on removing the cover to the HP 1200 Deskjet. It allowed me to removed a part that fell into the printer and prevented the paper from advancing.
karenliller@comcast.net - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 973
