HP Deskjet 1000 J110a Power Button Replacement
  1. HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: step 1, image 1 of 3 HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: step 1, image 2 of 3 HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: step 1, image 3 of 3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Power Button Replacement: step 2, image 1 of 3 HP Deskjet 1000 J110a Power Button Replacement: step 2, image 2 of 3 HP Deskjet 1000 J110a Power Button Replacement: step 2, image 3 of 3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Power Button Replacement: step 3, image 1 of 1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Power Button Replacement, Power Button: step 4, image 1 of 3 HP Deskjet 1000 J110a Power Button Replacement, Power Button: step 4, image 2 of 3 HP Deskjet 1000 J110a Power Button Replacement, Power Button: step 4, image 3 of 3
    • Carefully hold the small clip back to release the button arm.
    • Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot.
    • Replace the old power button with a new one.
Colin Tourjee
632 Reputation
4 Guides authored
USF Tampa, Team S5-G3, Passmore Spring 2018 Member of USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 393
