HP Deskjet 2624 Ink Cartridges Replacement
  1. HP Deskjet 2624 Ink Cartridges Replacement, Ink Cartridges: step 1, image 1 of 1
    • Unplug all of the cords from the printer and put paper into the input tray.
  2. HP Deskjet 2624 Ink Cartridges Replacement: step 2, image 1 of 3 HP Deskjet 2624 Ink Cartridges Replacement: step 2, image 2 of 3 HP Deskjet 2624 Ink Cartridges Replacement: step 2, image 3 of 3
    • Lower the output tray and the ink cartridge access door.
    • Lightly press forward on the cartridge to release it and then pull the cartridge straight out.
    • The slot on the left is the tri-color cartridge while the black cartridge is on the right.
  3. HP Deskjet 2624 Ink Cartridges Replacement: step 3, image 1 of 3 HP Deskjet 2624 Ink Cartridges Replacement: step 3, image 2 of 3 HP Deskjet 2624 Ink Cartridges Replacement: step 3, image 3 of 3
    • On the new cartridge, pull the colored tab to remove the plastic.
    • Hold the replacement with the nozzles toward the printer and insert it at an upward angle.
    • Push the cartridge forward until it snaps into place.
    • Repeat steps two and three if necessary.
After completing this guide, don’t forget to plug in your HP Deskjet 2624 .
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 1,216
