HP Deskjet 2624 Magnetic Strip Replacement
  1. HP Deskjet 2624 Magnetic Strip Replacement, Magnetic Strip: step 1, image 1 of 1
    • Unplug the printer and remove all paper from the input tray.
  2. HP Deskjet 2624 Magnetic Strip Replacement: step 2, image 1 of 2 HP Deskjet 2624 Magnetic Strip Replacement: step 2, image 2 of 2
    • Using the Torx T5 screwdriver, remove the four screws holding the scanner bed module to the printer base.
    • Slowly lift up the scanner bed slightly off the base.
    • Be sure to unplug the ribbons connecting the two parts by pulling them straight out of their plugs gently.
  3. HP Deskjet 2624 Magnetic Strip Replacement: step 3, image 1 of 2 HP Deskjet 2624 Magnetic Strip Replacement: step 3, image 2 of 2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Magnetic Strip Replacement: step 4, image 1 of 3 HP Deskjet 2624 Magnetic Strip Replacement: step 4, image 2 of 3 HP Deskjet 2624 Magnetic Strip Replacement: step 4, image 3 of 3
    • Locate the magnetic strip found running straight through the ink cartridge carriage.
  5. HP Deskjet 2624 Magnetic Strip Replacement: step 5, image 1 of 3 HP Deskjet 2624 Magnetic Strip Replacement: step 5, image 2 of 3 HP Deskjet 2624 Magnetic Strip Replacement: step 5, image 3 of 3
    • To remove the strip, start by applying pressure to the silver connection located on the right hand side of the strip.
    • While applying pressure to the right hand side, push the strip off the left hand hook and pull it straight up.
    • Lift the strip vertically and unhook it from the silver strip.
    • When putting the strip back in, ensure that the arrow on the replacement faces to the right and downwards.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 514
