HP Deskjet 2624 Scanner Glass Replacement
  1. HP Deskjet 2624 Scanner Glass Replacement, Scanner Glass: step 1, image 1 of 1
    • Unplug all cords from the printer, and remove all the paper from the tray.
  2. HP Deskjet 2624 Scanner Glass Replacement: step 2, image 1 of 2 HP Deskjet 2624 Scanner Glass Replacement: step 2, image 2 of 2
    • Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
  3. HP Deskjet 2624 Scanner Glass Replacement: step 3, image 1 of 1
    • Gently pry the scanner bed cover slightly off of the printer at the hinge.
    • Lifting the scanning bed cover to a 45 degree angle may make it easier to remove.
  4. HP Deskjet 2624 Scanner Glass Replacement: step 4, image 1 of 1
    • Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
    • Set the printer body aside.
  5. HP Deskjet 2624 Scanner Glass Replacement: step 5, image 1 of 3 HP Deskjet 2624 Scanner Glass Replacement: step 5, image 2 of 3 HP Deskjet 2624 Scanner Glass Replacement: step 5, image 3 of 3
    • Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
    • Pull the halves apart while undoing the clips to prevent plastic snapping.
  6. HP Deskjet 2624 Scanner Glass Replacement: step 6, image 1 of 2 HP Deskjet 2624 Scanner Glass Replacement: step 6, image 2 of 2
    • Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
    • Glass edges can be sharp, handle glass and glass shards with gloves.
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 31
All Time: 825
