HP Deskjet 930c Disassembly to clean Waste Ink Reservoir
  1. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir, HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 1, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir, HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 1, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir, HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 1, image 3 of 3
    • Carefully pry off the button board cover with a flat-head screwdriver.
    • Unplug and remove the button board.
    • Remove two screws that hold the printer's top piece in place with a TR8 Torx Security screwdriver.
  2. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 2, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 2, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 2, image 3 of 3
    • Remove the printer's lid.
    • Push in the tab shown to remove the top plastic assembly of the printer.
    • You don't have to remove the cartridge cover to do this. Though removing the cover makes it easier, it is not a required step.
  3. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 3, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 3, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 3, image 3 of 3
    • Remove the paper jam door from the printer by turning the dial from the locked position to the unlocked position.
  4. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 4, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 4, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 4, image 3 of 3
    • Push and lift the tabs shown with a flat-head screwdriver.
  5. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 5, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 5, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 5, image 3 of 3
    • Remove the top casing from the printer.
    • Unclip and pry off the side cover with a TR8 Torx Security Screwdriver.
    • Pry off the plastic casing with force; the TR8 Torx Security Screwdriver can help here.
  6. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 6, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 6, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 6, image 3 of 3
    • Remove the plastic piece covering the motor that controls the waste ink assembly.
    • Disconnect the motor connection.
  7. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 7, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 7, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 7, image 3 of 3
    • With the motor unplugged, move the ink cartridge carrier to the middle of the printer.
    • You can scroll the gear assembly with your finger if the carriage gets stuck.
    • Remove four screws from the back panel.
  8. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 8, image 1 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 8, image 2 of 3 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 8, image 3 of 3
    • Press the clip marked in red.
    • Slide it to the right.
    • Lift and remove this side.
  9. HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 9, image 1 of 2 HP Deskjet 930c Disassembly to clean Waste Ink Reservoir: step 9, image 2 of 2
    • Press where marked with the arrow and lift the waste ink reservoir.
    • Remove the motor and clean with high-pressured water.
14 other people completed this guide.
Bernard DU MORTIER
217 Reputation
1 Guide authored
9 Comments
Thanks so much, I was able to fix my bad paper feed jam on my Deskjet 952C using your disassembly instructions. Apparently you can take apart the 930C 932C 950C and 952C using similar methods.
kestrel77p - Reply
Merci pour l’aide.
Marc - Reply
Hello. Is it same too hp deskjet 9300?
chagii_r - Reply
I have no idea. I don’t have a HP deskjet 9300 printer.
Bernard DU MORTIER -
Many thanks for your instruction, Bernard. I was able to clean my DeskJet 970 cxi, because the waste ink leaked off the reservoir, as I transported the printer upside down :-( I’ve only got two additions, that I commented within the steps.
Heimwerker - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 51
All Time: 15,425
