HP Deskjet D1660 Encoder Strip Replacement
  1. HP Deskjet D1660 Encoder Strip Replacement, Encoder Strip: step 1, image 1 of 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Encoder Strip Replacement: step 2, image 1 of 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Encoder Strip Replacement: step 3, image 1 of 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Encoder Strip Replacement: step 4, image 1 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 4, image 2 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 4, image 3 of 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Encoder Strip Replacement: step 5, image 1 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 5, image 2 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 5, image 3 of 3
    • Looking at the printer from the front, carefully unhook the encoder strip from the left side.
    • Pull the strip to the left and push a little to unhook the strip.
    • Do the same thing on the other side by pulling to the right and pushing a little.
    • Pull the strip completely out from the cartridge holder.
3 other people completed this guide.
Justin Taiki Fukada
912 Reputation
7 Guides authored
Cal Poly, Team 1-41, Maness Winter 2014 Member of Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 77
All Time: 4,908
