HP Deskjet D1660 Gear Guard Replacement
  1. HP Deskjet D1660 Gear Guard Replacement, Top Cover: step 1, image 1 of 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Gear Guard Replacement: step 2, image 1 of 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Gear Guard Replacement: step 3, image 1 of 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Gear Guard Replacement: step 4, image 1 of 3 HP Deskjet D1660 Gear Guard Replacement: step 4, image 2 of 3 HP Deskjet D1660 Gear Guard Replacement: step 4, image 3 of 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: step 5, image 1 of 2 HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: step 5, image 2 of 2
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Gear Guard Replacement: step 6, image 1 of 2 HP Deskjet D1660 Gear Guard Replacement: step 6, image 2 of 2
    • Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer.
    • Now detach the white strip and wires by gently lifting them up.
  7. HP Deskjet D1660 Gear Guard Replacement, Gear Guard: step 7, image 1 of 1
    • The gear guard will be located on the left side of the printer.
    • Grab the plastic guard and lift it up.
Justin Taiki Fukada
891 Reputation
7 Guides authored
Cal Poly, Team 1-41, Maness Winter 2014 Member of Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,194
