HP ENVY 5530 Front Panel Replacement
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: step 2, image 1 of 3 HP ENVY 5530 Front Panel Replacement: step 2, image 2 of 3 HP ENVY 5530 Front Panel Replacement: step 2, image 3 of 3
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
  3. HP ENVY 5530 Front Panel Replacement: step 3, image 1 of 2 HP ENVY 5530 Front Panel Replacement: step 3, image 2 of 2
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
Elizabeth Surface
1,465 Reputation
9 Guides authored
USF Tampa, Team 4-6, Meier Fall 2015 Member of USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Members
18 Guides authored
4 Comments
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - Reply
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - Reply
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - Reply
Where does the cable go?
Victorian Lover - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 2,166
