HP ENVY 5530 Front Panel Replacement
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: step 2, image 1 of 3 HP ENVY 5530 Front Panel Replacement: step 2, image 2 of 3 HP ENVY 5530 Front Panel Replacement: step 2, image 3 of 3
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
    On some printer version, you may find a single torx 10 screw under the right sticker.
    Remove it and then slide the panel to the right then to the top.
    Easy as said!
    No need to use any spudger.
    Learned it the hard way ;)
    Cecil His Mahier - Reply
  3. HP ENVY 5530 Front Panel Replacement: step 3, image 1 of 2 HP ENVY 5530 Front Panel Replacement: step 3, image 2 of 2
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
    There’s a screw undcer the model label on the right. Peel the label up right to left to expose the screw, remove the screw to lift the front panel off.
    sel full - Reply
Elizabeth Surface
1,465 Reputation
9 Guides authored
USF Tampa, Team 4-6, Meier Fall 2015 Member of USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Members
18 Guides authored
4 Comments
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - Reply
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - Reply
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - Reply
Where does the cable go?
Victorian Lover - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 2,166
