HP ENVY 5530 Power Supply Replacement
  1. HP ENVY 5530 Power Supply Replacement, AC Adaptor: step 1, image 1 of 3 HP ENVY 5530 Power Supply Replacement, AC Adaptor: step 1, image 2 of 3 HP ENVY 5530 Power Supply Replacement, AC Adaptor: step 1, image 3 of 3
    • Open the the printer by lifting the top section. Make sure you're lifting from the lowest portion of the scanner section.
  2. HP ENVY 5530 Power Supply Replacement: step 2, image 1 of 3 HP ENVY 5530 Power Supply Replacement: step 2, image 2 of 3 HP ENVY 5530 Power Supply Replacement: step 2, image 3 of 3
    • Locate 13mm TR10 Torx Security screw behind screen and remove using Torx screwdriver.
  3. HP ENVY 5530 Power Supply Replacement: step 3, image 1 of 3 HP ENVY 5530 Power Supply Replacement: step 3, image 2 of 3 HP ENVY 5530 Power Supply Replacement: step 3, image 3 of 3
    • Remove case covering by lifting it up to reveal the power cord.
  4. HP ENVY 5530 Power Supply Replacement: step 4, image 1 of 2 HP ENVY 5530 Power Supply Replacement: step 4, image 2 of 2
    • Locate power cord.
    • Pull it out.
  5. HP ENVY 5530 Power Supply Replacement: step 5, image 1 of 2 HP ENVY 5530 Power Supply Replacement: step 5, image 2 of 2
    • Locate 13mm TR10 Torx Security screw behind screen and remove with screwdriver.
  6. HP ENVY 5530 Power Supply Replacement: step 6, image 1 of 2 HP ENVY 5530 Power Supply Replacement: step 6, image 2 of 2
    • Use a metal spudger around the edge to remove AC adapter cover.
  7. HP ENVY 5530 Power Supply Replacement: step 7, image 1 of 1
    • Pull the AC adaptor up and out of its casing
  8. HP ENVY 5530 Power Supply Replacement: step 8, image 1 of 3 HP ENVY 5530 Power Supply Replacement: step 8, image 2 of 3 HP ENVY 5530 Power Supply Replacement: step 8, image 3 of 3
    • Disconnect the wires from the AC adaptor.
    • Replace AC Adapter box. Reverse order of instructions for reassembly.
3 other people completed this guide.
Justin
295 Reputation
1 Guide authored
USF-Leahy-S18S1G1 Member of USF-Leahy-S18S1G1
Community
3 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,803
