HP Elite X2 1013 G3 Battery Replacement
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: step 1, image 1 of 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: step 2, image 1 of 2 HP Elite X2 1013 G3 Battery Replacement: step 2, image 2 of 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: step 3, image 1 of 2 HP Elite X2 1013 G3 Battery Replacement: step 3, image 2 of 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: step 4, image 1 of 2 HP Elite X2 1013 G3 Battery Replacement: step 4, image 2 of 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: step 5, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: step 6, image 1 of 1
    • Lift the battery out of the housing.
Asmita Sharma
186 Reputation
1 Guide authored
Cal Poly, Team S9-G12, Maness Spring 2019 Member of Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 43
All Time: 2,585
