HP Elite X2 G4 Display Assembly Replacement
  1. HP Elite X2 G4 Display Assembly Replacement, Display Assembly: step 1, image 1 of 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite X2 G4 Display Assembly Replacement: step 2, image 1 of 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite X2 G4 Display Assembly Replacement: step 3, image 1 of 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite X2 G4 Display Assembly Replacement: step 4, image 1 of 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite X2 G4 Display Assembly Replacement: step 5, image 1 of 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
Goncalo Felix
325 Reputation
3 Guides authored
One Comment
Boa tarde Gonçalo.
Sabe dizer-me onde posso comprar um ecrã original para o meu HP Elite X2 G4?
Obrigado
Pedro Santos
Pedro_Neno - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 605
