HP Elite x2 1012 G2 Prop Stand Replacement
  1. HP Elite x2 1012 G2 Prop Stand Replacement, Prop Stand: step 1, image 1 of 2 HP Elite x2 1012 G2 Prop Stand Replacement, Prop Stand: step 1, image 2 of 2
    • Lift the prop stand approximately 140 degrees from its home position to expose two T5 Torx head screws.
  2. HP Elite x2 1012 G2 Prop Stand Replacement: step 2, image 1 of 1
    • Use the T5 Torx bit to remove both screws from the prop stand pivot points.
  3. HP Elite x2 1012 G2 Prop Stand Replacement: step 3, image 1 of 1
    • Gently pull the stand away from the device until you can lift the prop stand away from the device.
kefil
106 Reputation
1 Guide authored
IUPUI, Team S13-G13, Wilson Spring 2019 Member of IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,010
