HP Elite x2 1012 G2 Screen Replacement
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: step 1, image 1 of 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: step 2, image 1 of 3 HP Elite x2 1012 G2 Screen Replacement: step 2, image 2 of 3 HP Elite x2 1012 G2 Screen Replacement: step 2, image 3 of 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: step 3, image 1 of 2 HP Elite x2 1012 G2 Screen Replacement: step 3, image 2 of 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Screen Replacement: step 4, image 1 of 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: step 5, image 1 of 3 HP Elite x2 1012 G2 Screen Replacement: step 5, image 2 of 3 HP Elite x2 1012 G2 Screen Replacement: step 5, image 3 of 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: step 6, image 1 of 2 HP Elite x2 1012 G2 Screen Replacement: step 6, image 2 of 2
    • Remove the screen by gently lifting it off of the device.
4 other people completed this guide.
Noah Stapp
758 Reputation
2 Guides authored
Cal Poly, Team S18-G5, Livingston Spring 2018 Member of Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 Members
13 Guides authored
5 Comments
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - Reply
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - Reply
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - Reply
The touch stopped working after the replacement. Any suggestions?
el._.msn - Reply
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - Reply
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 124
All Time: 8,647
