Introduction
If the tablet experiences one of the three symptoms below, there might be a problem with the motherboard.
- The initial start-up functions appear like indicative light, fan, and hard drive sound, but disappears after a while, i.e., 5 – 3 minutes.
- A high pitched sound comes from the laptop when you press the “on” button.
- Your screen is projecting a black screen, even though all other components such as fans, indication light and hard drive seems to be working perfectly.
Before going through the replacement process, make sure your tablet is turned off and not connected to the power cord.
3 other people completed this guide.
One Comment
¿basta con esto para cambiar el cable LCD?
Is this enough to replace the LCD wire?
