HP EliteBook 1040 G4 Battery Replacement
  1. HP EliteBook 1040 G4 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Battery Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Battery Replacement: step 2, image 2 of 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Battery Replacement, Battery: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Battery Replacement: step 4, image 1 of 2 HP EliteBook 1040 G4 Battery Replacement: step 4, image 2 of 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Battery Replacement: step 5, image 1 of 2 HP EliteBook 1040 G4 Battery Replacement: step 5, image 2 of 2
    • Lift and remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Hannah DiMartino
395 Reputation
3 Guides authored
Clemson, Team 4-1, Hunter Fall 2021 Member of Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 44
All Time: 1,210
