HP EliteBook 1040 G4 Display Replacement
  1. HP EliteBook 1040 G4 Display Replacement, Display: step 1, image 1 of 1
    • Wedge an opening tool between the display and the chassis, gently prying around the perimeter until the display completely releases.
  2. HP EliteBook 1040 G4 Display Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Display Replacement: step 2, image 2 of 2
    • Lift the metal arm, then pull the display ribbon cable directly out of its port.
  3. HP EliteBook 1040 G4 Display Replacement: step 3, image 1 of 2 HP EliteBook 1040 G4 Display Replacement: step 3, image 2 of 2
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  4. HP EliteBook 1040 G4 Display Replacement: step 4, image 1 of 1
    • Remove the hinge cover.
  5. HP EliteBook 1040 G4 Display Replacement: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 5 mm black screws that securing the dispaly.
  6. HP EliteBook 1040 G4 Display Replacement: step 6, image 1 of 2 HP EliteBook 1040 G4 Display Replacement: step 6, image 2 of 2
    • Lift the display up and out of its housing.
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 17
All Time: 1,198
