HP EliteBook 1040 G4 Fan Replacement
  1. HP EliteBook 1040 G4 Fan Replacement, Back Cover: step 1, image 1 of 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Fan Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Fan Replacement: step 2, image 2 of 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Fan Replacement, Fan: step 3, image 1 of 2 HP EliteBook 1040 G4 Fan Replacement, Fan: step 3, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
    • The top left screw may be hidden under shielding tape.
  4. HP EliteBook 1040 G4 Fan Replacement: step 4, image 1 of 3 HP EliteBook 1040 G4 Fan Replacement: step 4, image 2 of 3 HP EliteBook 1040 G4 Fan Replacement: step 4, image 3 of 3
    • Remove the electrical tape to expose the heat sink screws.
    • Using the Phillips #0 screwdriver, unscrew the four screws securing the heatsink to the motherboard.
    • Carefully disconnect the pin connector by pulling it from its slot.
  5. HP EliteBook 1040 G4 Fan Replacement: step 5, image 1 of 1
    • Carefully remove the wires from the clip to the left of the fan.
  6. HP EliteBook 1040 G4 Fan Replacement: step 6, image 1 of 2 HP EliteBook 1040 G4 Fan Replacement: step 6, image 2 of 2
    • Lift and remove the fan and heatsink assembly from the device.
Hannah DiMartino
395 Reputation
3 Guides authored
Clemson, Team 4-1, Hunter Fall 2021 Member of Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 27
All Time: 623
