HP EliteBook 1040 G4 Trackpad Replacement
  1. HP EliteBook 1040 G4 Trackpad Replacement, Back Cover: step 1, image 1 of 1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Trackpad Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Trackpad Replacement: step 2, image 2 of 2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Trackpad Replacement, Battery: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Trackpad Replacement: step 4, image 1 of 2 HP EliteBook 1040 G4 Trackpad Replacement: step 4, image 2 of 2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Trackpad Replacement: step 5, image 1 of 2 HP EliteBook 1040 G4 Trackpad Replacement: step 5, image 2 of 2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Trackpad Replacement, Trackpad: step 6, image 1 of 1
    • Peel back the foam cover to reveal the underside of the trackpad.
  7. HP EliteBook 1040 G4 Trackpad Replacement: step 7, image 1 of 1
    • Carefully disconnect the white ribbon cable attached to the underside of the trackpad.
  8. HP EliteBook 1040 G4 Trackpad Replacement: step 8, image 1 of 1
    • Carefully disconnect the black ribbon cable attached to the chassis.
  9. HP EliteBook 1040 G4 Trackpad Replacement: step 9, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws securing the trackpad.
  10. HP EliteBook 1040 G4 Trackpad Replacement: step 10, image 1 of 1
    • Lift and remove the trackpad from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 312
