HP EliteBook 745 G4 Battery Replacement
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: step 2, image 1 of 1
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: step 3, image 1 of 2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: step 3, image 2 of 2
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: step 4, image 1 of 1
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: step 5, image 1 of 1
    • Loosen the two captive screws and remove the battery from the computer
To replace the battery & reassemble your device, follow these instructions in reverse order.
3 other people completed this guide.
Max Kletskov
40,418 Reputation
16 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,086 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 43
All Time: 1,298
