HP EliteBook 745 G6 RAM Replacement
  1. HP EliteBook 745 G6 RAM Replacement, RAM: step 1, image 1 of 1
    • Type CMD in the Start Menu and open Command Prompt.
    • Type the following command to view memory details and press Enter.
    • wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor.
  2. HP EliteBook 745 G6 RAM Replacement: step 2, image 1 of 1
    • Power off the Notebook.
    • Select the Start button.
    • Select the Power button.
    • Select Shut down.
    • Disconnect the power adapter.
  3. HP EliteBook 745 G6 RAM Replacement: step 3, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 3, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Turn the notebook upside down on a flat surface.
    • Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
    • Pry the bottom cover with plastic card or spudger at the bottom right corner.
    • Lift the bottom cover off with plastic card.
  4. HP EliteBook 745 G6 RAM Replacement: step 4, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 4, image 2 of 2
    Anti-Static Wrist Strap
    $7.95
    Buy
  5. HP EliteBook 745 G6 RAM Replacement: step 5, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 5, image 2 of 2
    • Be sure to ground yourself by wearing anti-static wrist strap.
    • Do not remove memory shielding from the system board when replacing memory.
    • The socket labeled 2 houses the expansion memory module and the socket labeled 1 houses the primary memory module.
    • Spread the retaining tabs on each side of the memory module slot to release the memory module.
    • Pull the memory module away from the slot at an angle.
  6. HP EliteBook 745 G6 RAM Replacement: step 6, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 6, image 2 of 2
    • Insert the memory module into the slot at an angle.
    • Push down the center of memory module until the retaining tabs lock the RAM stick.
  7. HP EliteBook 745 G6 RAM Replacement: step 7, image 1 of 1
    • Insert the battery cable into the system board.
  8. HP EliteBook 745 G6 RAM Replacement: step 8, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 8, image 2 of 2
    • Push down the bottom cover at the four corner and center.
    • Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
  9. HP EliteBook 745 G6 RAM Replacement: step 9, image 1 of 1
    • Push the power button.
  10. HP EliteBook 745 G6 RAM Replacement: step 10, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 10, image 2 of 2
    • Right-click on the taskbar.
    • Select the “Task Manager”.
    • Select the "Performance".
Mengqi Shi
208 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 79
All Time: 2,777
