HP EliteBook 840 G7 Battery Replacement
Pedro Ramos Espinoza
Pedro Ramos Espinoza and 2 other contributors
Last updated on March 20, 2025
15 minutes
Easy
Community-Contributed Guide
Introduction
Go to step 1
This guide will show you how to replace the battery on a HP Elitebook 840 G7. You can remove and replace your battery by simply following these steps.
The battery powers the device so that it can operate without an external power source.
To know if you have a faulty battery signs include: Fast loss of power, Does not power up, Fails to power on without external power source.
Before using this guide be sure to look at out troubleshooting page to ensure that the battery is the problem.
Tools
  1. HP EliteBook 840 G7 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Battery Replacement: step 2, image 1 of 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Battery Replacement: step 3, image 1 of 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Battery Replacement: step 4, image 1 of 3 HP EliteBook 840 G7 Battery Replacement: step 4, image 2 of 3 HP EliteBook 840 G7 Battery Replacement: step 4, image 3 of 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Battery Replacement: step 5, image 1 of 3 HP EliteBook 840 G7 Battery Replacement: step 5, image 2 of 3 HP EliteBook 840 G7 Battery Replacement: step 5, image 3 of 3
    • Lift up the battery with you hands or tools.
895 Reputation
4 Guides authored
Gateway, Team 1-1, Pee Spring 2022 Member of Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 56
Past 30 Days: 169
All Time: 3,628
