HP EliteBook 840 G7 keyboard Replacement
Pedro Ramos Espinoza
Pedro Ramos Espinoza and 2 other contributors
Last updated on March 20, 2025
25 minutes
Moderate
Community-Contributed Guide
Introduction
Go to step 1
Use this guide to replace the keyboard on a HP EliteBook 840 G7
Parts
Tools
Show more…
  1. HP EliteBook 840 G7 keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 keyboard Replacement: step 2, image 1 of 1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 keyboard Replacement: step 3, image 1 of 1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 keyboard Replacement: step 4, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 4, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 4, image 3 of 3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 keyboard Replacement: step 5, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 5, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 5, image 3 of 3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 keyboard Replacement, Display Assembly: step 6, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement, Display Assembly: step 6, image 2 of 2
    • Pull up to remove the two coaxial Wi-Fi card connectors.
  7. HP EliteBook 840 G7 keyboard Replacement: step 7, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement: step 7, image 2 of 2
    • Pull upwards on the display connector to remove.
  8. HP EliteBook 840 G7 keyboard Replacement: step 8, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement: step 8, image 2 of 2
    • Pull or push to remove the bundled cable connector.
  9. HP EliteBook 840 G7 keyboard Replacement: step 9, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement: step 9, image 2 of 2
    • Pull upwards to remove the webcam connector.
  10. HP EliteBook 840 G7 keyboard Replacement: step 10, image 1 of 1
    • Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
  11. HP EliteBook 840 G7 keyboard Replacement: step 11, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement: step 11, image 2 of 2
    • Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
  12. HP EliteBook 840 G7 keyboard Replacement: step 12, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement: step 12, image 2 of 2
    • Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
  13. HP EliteBook 840 G7 keyboard Replacement: step 13, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 13, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 13, image 3 of 3
    • Open the laptop to a 90 degree angle.
    • Slide the display hinges away to remove the display assembly.
  14. HP EliteBook 840 G7 keyboard Replacement, Keyboard: step 14, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement, Keyboard: step 14, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement, Keyboard: step 14, image 3 of 3
    • Pull on the bundled connector to remove.
    • Remove the speaker system from the board.
  15. HP EliteBook 840 G7 keyboard Replacement: step 15, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement: step 15, image 2 of 2
    • Push away to remove the bundled connector from its port.
    • Move the cable away from the ZIF connector below.
  16. HP EliteBook 840 G7 keyboard Replacement: step 16, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 16, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 16, image 3 of 3
    • Lift the latch on the ZIF connector.
    • Pull away on the connector to remove.
  17. HP EliteBook 840 G7 keyboard Replacement: step 17, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 17, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 17, image 3 of 3
    • Use your Phillips #1 screwdriver to remove the three 1.3 mm screws.
    • Lift up and away to remove the USB ports.
  18. HP EliteBook 840 G7 keyboard Replacement: step 18, image 1 of 2 HP EliteBook 840 G7 keyboard Replacement: step 18, image 2 of 2
    • Push away to remove the bundled connector.
  19. HP EliteBook 840 G7 keyboard Replacement: step 19, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 19, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 19, image 3 of 3
    • Use your Phillips # 1 screwdriver to remove the three 1.2 mm screws that hold the fan in place.
    • Lift up from the left side of the fan then pull towards you to remove.
  20. HP EliteBook 840 G7 keyboard Replacement: step 20, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 20, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 20, image 3 of 3
    • After removing the connector pull off the CMOS battery.
  21. HP EliteBook 840 G7 keyboard Replacement: step 21, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 21, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 21, image 3 of 3
    • Use your Phillips #1 screwdriver to remove the single 1.2 mm screw.
    • Pull on the cable to remove the charging port.
  22. HP EliteBook 840 G7 keyboard Replacement: step 22, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 22, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 22, image 3 of 3
    • Lift on the latch on the ZIF connector.
    • Pull on the cable to remove.
  23. HP EliteBook 840 G7 keyboard Replacement: step 23, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 23, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 23, image 3 of 3
    • Release the latch on the ZIF connector.
    • Carefully pull the connector to remove.
  24. HP EliteBook 840 G7 keyboard Replacement: step 24, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 24, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 24, image 3 of 3
    • Use you Phillips #1 screwdriver to remove the eight 1.2 mm screws.
    • Lift the whole board up to remove.
  25. HP EliteBook 840 G7 keyboard Replacement: step 25, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 25, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 25, image 3 of 3
  26. HP EliteBook 840 G7 keyboard Replacement: step 26, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 26, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 26, image 3 of 3
  27. HP EliteBook 840 G7 keyboard Replacement: step 27, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 27, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 27, image 3 of 3
    • Use your Phillips #000 screwdriver to remove the four 1 mm screws.
    • Pull up to remove.
    • Careful to not harm other cables.
  28. HP EliteBook 840 G7 keyboard Replacement: step 28, image 1 of 3 HP EliteBook 840 G7 keyboard Replacement: step 28, image 2 of 3 HP EliteBook 840 G7 keyboard Replacement: step 28, image 3 of 3
    • Use your Phillips #000 screwdriver to remove the five 1 mm screws.
    • Lift the touchpad to remove.
7 other people completed this guide.
895 Reputation
4 Guides authored
Gateway, Team 1-1, Pee Spring 2022 Member of Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Members
12 Guides authored
4 Comments
Donc ce tuto permet de tout enlever sauf le clavier?
Pilc - Reply
This is only replacement of the touchpad?
Where is the keyboard replacement?
Koehoe22 - Reply
the keyboard is part of the top shell and is rivetted in, you need to replace the whole part
Leonardo Di Stefano -
Recommended parts are wrong
Daniel Caltrider - Reply
Past 24 Hours: 11
Past 7 Days: 72
Past 30 Days: 435
All Time: 14,880
