HP EliteBook 850 G3 Battery Replacement
Annabeth Grover
Annabeth Grover and 5 other contributors
Last updated on March 29, 2024
2 minutes
Very easy
Introduction
Go to step 1
If your HP EliteBook 850 G3 is not holding a charge use this guide to replace the battery. The battery powers the laptop if it is faulty the computer will not keep a charge. If your battery is swollen this is urgent and dangerous. Be sure to rule out a faulty cord and other common issues that could be preventing your battery from charging properly. Before using this guide, feel free to check out the troubleshooting page to see if any issues can be resolved without a replacement.
Parts
Tools
Show more…
  1. HP EliteBook 850 G3 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: step 2, image 1 of 2 HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Battery Replacement: step 3, image 1 of 2 HP EliteBook 850 G3 Battery Replacement: step 3, image 2 of 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: step 4, image 1 of 2 HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: step 4, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Battery Replacement, Lift the battery: step 5, image 1 of 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: step 5, image 2 of 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: step 5, image 3 of 3
    • Lift and pull the flap located at the top of the battery to remove it.
5 other people completed this guide.
Annabeth Grover
946 Reputation
5 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2019 Member of USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Members
6 Guides authored
2 Comments
Thank you very much for this guide.
Geoff Taylor - Reply
When charging the charging indicator remain orange for hours and does not change.
Raymond Malken - Reply
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 106
All Time: 10,311
