HP EliteBook 850 G3 Battery Replacement
  1. HP EliteBook 850 G3 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: step 2, image 1 of 2 HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Battery Replacement: step 3, image 1 of 2 HP EliteBook 850 G3 Battery Replacement: step 3, image 2 of 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: step 4, image 1 of 2 HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: step 4, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Battery Replacement, Lift the battery: step 5, image 1 of 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: step 5, image 2 of 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: step 5, image 3 of 3
    • Lift and pull the flap located at the top of the battery to remove it.
5 other people completed this guide.
Annabeth Grover
946 Reputation
5 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2019 Member of USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Members
6 Guides authored
2 Comments
Thank you very much for this guide.
Geoff Taylor - Reply
When charging the charging indicator remain orange for hours and does not change.
Raymond Malken - Reply
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 116
All Time: 10,323
