HP EliteBook 850 G7 Battery Replacement
  1. HP EliteBook 850 G7 Battery Replacement, Battery: step 1, image 1 of 2 HP EliteBook 850 G7 Battery Replacement, Battery: step 1, image 2 of 2
    • To start flip the device so the bottom is facing up
  2. HP EliteBook 850 G7 Battery Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 Battery Replacement: step 2, image 2 of 2
    • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
    • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
  3. HP EliteBook 850 G7 Battery Replacement: step 3, image 1 of 2 HP EliteBook 850 G7 Battery Replacement: step 3, image 2 of 2
    • Unplug the battery cable
    • Then remove the 4 marked screws.
    • The battery can now be removed
    • For reassembly just follow the directions in reverse
Caleb Pierce
230 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 10
All Time: 10
