HP EliteBook 850 G7 Fan Replacement
  1. HP EliteBook 850 G7 Fan Replacement, Fan: step 1, image 1 of 2 HP EliteBook 850 G7 Fan Replacement, Fan: step 1, image 2 of 2
    • To start flip the device so the bottom is facing up
  2. HP EliteBook 850 G7 Fan Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 Fan Replacement: step 2, image 2 of 2
    • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
    • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
  3. HP EliteBook 850 G7 Fan Replacement: step 3, image 1 of 3 HP EliteBook 850 G7 Fan Replacement: step 3, image 2 of 3 HP EliteBook 850 G7 Fan Replacement: step 3, image 3 of 3
    • Unplug both marked cables. For the larger one pull it straight up gently but firmly.
    • Pull the cables out of the channels.
    • Extremely gently remove the remaining cables from the channels
    • Unscrew the marked screws.
  4. HP EliteBook 850 G7 Fan Replacement: step 4, image 1 of 2 HP EliteBook 850 G7 Fan Replacement: step 4, image 2 of 2
    • Be careful to only pull on the plastic end of the cable.
    • Using a pair of tweezers or a spudger pull the fan cable out
    • The fan can now be removed
Caleb Pierce
230 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 5
All Time: 5
